ENGINE DIES
MANDOLIN JON
04-22-2005 18:09:25
For some strange reason my 9n dies after operating for 30 minutes or so. I suspect that there is something electrical that kills the engine. Any suggestions about what could be happening?
Russ SoCal
04-23-2005 00:37:03
 Dell (WA)'s diagnostics in reply to MANDOLIN JON, 04-22-2005 18:09:25
Runs one-minute and quits = condenser. Starts up again and quits again.
Runs three- to five-minutes and quits = fuel line screens. Will stumble and not start unless you wait a few or several minutes.
Runs 15-minutes and quits = ignition switch. Will restart or not after some several minutes. It will do it again after lunch.
Runs 40- to 60-minutes and quits = front-mount coil. Needs to cool off for an hour or so.
mandolin jon
04-23-2005 01:54:50
 Re: Dell (WA)'s diagnostics in reply to Russ SoCal, 04-23-2005 00:37:03
Thanks for the input guys. I think it is the coil because of Del's diagonsis fits. The spark plugs are new. I just recently reset the points but I didn't replace the condensor. However, the coil is older than the points and condensor which were new when I got the tractor. It don't think its gas line problems because I have gone through that check.
souNdguy
04-22-2005 21:10:00
 Re: ENGINE DIES in reply to MANDOLIN JON, 04-22-2005 18:09:25
Do some diagnostics. next time it dies.. pull a plug wire and have a spare plug handy.. do a spark check. If you have spark.. check for fuel at the bottom plug ont he carb. Once you find out which system is a t fault.. check p the line.
My bet is electrical.
Soundguy
jwm
04-22-2005 18:37:42
More than likely it"s your ignition switch or maybe your coil. To check the ignition switch just jumper across it the next time it dies. Jmaes
