Carb. Vertical exhaust?
Rusty 2N
04-23-2005 09:48:42
This is a "44 2N, engine rebuiult 4 years ago. Replaced manifold & mounted vertical exhaust, pipe runs up behind gen. & in front of carb. This last winter the carb started leaking at the floatbowl gasket. Put a kit in it then & just had to replace the gasket again. Both surfaces seem to be straight & smooth. Is it possible that the exhaust is is getting the carb to warm? Also a ?? on the radiator. Just had it checked, said it was good, When I turn off the tractor I can hear a hissing at the rad. cap. Why?? Gonna pull the stat later & test it. Thank you for all help in adv. Enjoy your weekend!
Bob329
04-23-2005 16:28:15
 Re: Carb. Vertical exhaust? in reply to Rusty 2N, 04-23-2005 09:48:42
My 8N had a vertical exhaust rigged up when I bought it. Pipe ran about 1/64th of an inch from the carb. I feel confident the heat would cause some warpage of carb and tough on gasket. I changed my exhaust to origional location.
Bob
04-23-2005 16:47:06
 Re: Carb. Vertical exhaust? in reply to Bob329, 04-23-2005 16:28:15
"Horsefeathers" on the exhaust pipe warping the carburetor!
Before the carb could get hot enough to warp, every drop of gas would have to be boiled out of it, and long before it got that hot, it wouldn't be runn'in worth a darn, with the carb THAT HOT!
Bob
04-23-2005 17:01:55
 Re: Carb. Vertical exhaust? in reply to Bob, 04-23-2005 16:47:06
P.S.
If you really feel it's too hot, make a simple heat shield out of a piece of tin, bend a couple of tabs on it, and use a couple of worm gear hoseclamps to secure it to the pipe, with an airgap on both sides of the tin.
ButtonRock
04-24-2005 05:30:26
 Re: Carb. Vertical exhaust? in reply to Bob, 04-23-2005 17:01:55
Never had a problem in the six years of running a vertical on the 44. Enjoy the day
