Balls
Rod
03-31-2001 14:27:32
I just pulled the govenor off my 52 8N and I don't see anything worn out. The govenor lever kept pulling the throttle back to the 1/2 position so I could only run at 1/2 speed. I thought I would find something broken. What should I do now?
Claus
03-31-2001 15:25:50
 Re: Balls in reply to Rod, 03-31-2001 14:27:32
Your problem is probably not the govenor but in the throttle mechanism. The throttle quadrants wear out as well as the little ball on the bottom of the throttle control. I repaired mine by buying a new quadrant plate from one of our sponsors as well as replacing the spring on the bottom of the throttle rod. Ensure that you have maximum compression on the bottom spring. Also, make sure that the spring from the lower arm that connects to the bellhousing did not get lost.
Happy Motoring
Claus
