Governer or Carb????
RuintTX
04-25-2005 18:06:01
All of a sudden it seems like my governer isn"t responding - bogging a good bit under load, etc. Grabbed the rod in between carb and governer and it does fight back when jiggled. Suspect the carb but the old 8N is running like a top. Throttle response is awesome, under load or just free-wheeling.Any bog-down is easily overcome by throttle input. Just an annoyance right now - worried about a failure later. Spring is here in North Texas, I need the old girl for a few months weekly, without her having a nervous breakdown, but don"t want to make her mad. Air flow is defenitely good. ??-Sparkies -?? (Copper core wires, good gap, front mount distributor adjusted correctly)
Upper Peninsula,Mi
04-25-2005 19:52:19
 Re: Governer or Carb???? in reply to RuintTX, 04-25-2005 18:06:01
RuintTX. I've had this happen a couple of times. I just adjusted the main jet out 1/8 to 1/4 turn and that fixed it. Needed a little more gas. Good luck. Ron
jiminoystercreek
04-25-2005 19:49:46
Governor could still be a problem, with flat spots on the balls or grooved cone race. It don;t take long to pull it and see.
