how long can a key be on?
ratropia
04-26-2005 13:40:56
Hi ya' all. I have a 49 8N 6 volt front mount dist.I would like to know how long can a key be in the on position before the battery will run down? Or does it have to do with the position of the points wether or not it will run down the battery?
Thanks Rick T.
Steve (Magnolia, TX)
04-27-2005 06:58:29
 Re: how long can a key be on? in reply to ratropia, 04-26-2005 13:40:56
The last time I did that, it was overnight... and I burned my points. The battery wasn't completely dead, but it did need a charge...
HTH
Steve
BigGeorge
04-26-2005 14:35:37
If the points are closed they can weld themselves togeather if the key is left on for a long period of time.
guest
04-26-2005 13:58:41
You can leave it on foreaver, as long
as the points are open. If there is
a neg 2 Amps they are closed and it will
kill the bat in a number of hours.
ratropia
04-26-2005 14:23:49
 Re: how long can a key be on? in reply to guest, 04-26-2005 13:58:41
Thats what I thought, thanks for the answer.
