Can you pull a tappet cover with out pulling
old
04-26-2005 15:49:13
The intake/exhuast manifold?? If the answer is yes how, I tried to pull the front cover to take a look at the valve in #1 cylinder but can't get it off it hits on the gov. rod and the manifold. Any ideas before I just plan pull the head, manifold and tappet cover.
ClarkNidaho
04-26-2005 16:38:07
 Re: Can you pull a tappet cover with out pulling in reply to old, 04-26-2005 15:49:13
You do not need to pull the manifold to adjust tappets. As I recall I pulled the choke rod and disconnected linkage rods and probably the intake tube, been awhile, but definately doable.
Jeb2N
04-26-2005 15:54:13
Try tilting the end that is away from the governer out as far as it will go and possibly twisting it down and out and see if that helps. I did all my valve work prior to manifold/governor installation after the engine rebuild.
Jeb
old
04-26-2005 16:00:35
 Re: Can you pull a tappet cover with out pulling in reply to Jeb2N, 04-26-2005 15:54:13
Tried that the stud sticks out just enough that it will not let it come off, I'm just trying to save haveing to pull the head because of a valve in number 1 cylinder that isn't working as it should be. Sort of hopeing that the valve spring or some thing is loose in there
Jeb2N
04-26-2005 16:39:36
 Re: Can you pull a tappet cover with out pulling in reply to old, 04-26-2005 16:00:35
If your manifold is in reasonably good shape, just loosen the nuts enough to where it will tilt out and let the cover come off. It goes without saying to remove the governor linkage rods. Once you get it off, remove the spark plugs and have a friend turn the engine over with a hand crank while you inspect the valves. Or you could "cheat" and use the starter with the plugs removed.
Jeb
