Replacing Rubber Boot on Shifter
Old8Ner
04-01-2001 08:35:25
Is there a secret to replacing the rubber boot on the shifter?I can't get it to stretch over the base of the shifter.Any help appreciated. THANKS!!!
Dell (WA)
04-01-2001 12:47:55
 Re: Replacing Rubber Boot on Shifter in reply to Old8Ner, 04-01-2001 08:35:25
I used my 4-finger elastizer pliers that I use for stretching the little rubber castration rings for little boy lambies.
Most people have eazier access to boiling water to soften the tranny shifter boot so it will stretch over everything..... ...Dell
rbell
04-02-2001 09:44:34
 Re: Re: Replacing Rubber Boot on Shifter in reply to Dell (WA), 04-01-2001 12:47:55
Thant explains the comments and diagrams I saw on the "Dells Boy Lambies" web site. Something about what was going to happen to that guy with that four finger thing-a-ma-gig if he ever turns his back. :-)
funny......Dell (WA)
04-02-2001 14:59:05
 Re: Re: Re: Replacing Rubber Boot on Shifter in reply to rbell, 04-02-2001 09:44:34
grins
Paul in VA
04-01-2001 15:09:40
Dell,
Have you ever used the clamp type of emasculators? I also use the rubber rings on my lambs, but have been told that the the Burdizos give fewer problems. (Only problems I've ever had are one (fatal) case of tetenus (years ago...always cover with tetenus shot now) and an occasional problem getting the balls to stay below the rubber ring when I release it).
Paul
Dell (WA)
04-02-2001 14:58:01
 Re: Re: Re: Replacing Rubber Boot on Shifter in reply to Paul in VA, 04-01-2001 15:09:40
Paul..... .I've never had problems with the little rubber donuts. No, I've never used the Burdizos emasculators, and I'm glad I don't have to do it the old fashioned way with my teeth. I have some lady friends that have problems getting both testicles (grin)..... ...Dell
Paul in VA
04-01-2001 11:45:50
I first tried greasing the boot and had one classic he11 of a time with it. Then I removed the grease (which allowed me to get a better grip) and was able to stretch it over and on.
Boiling rubber? It works for cork, as I learned in my flyrod building and old motorcycle clutch days. I don't think it should do any long term harm to the rubber, but am puzzled to read that it might soften it. Maybe it's just being softened by the heat? (I'd think the water would not affect the rubber) so you should be able to use other heat sources...then again, boiling is safe in that it limits the heat to your local boiling point.
don b
04-01-2001 09:13:49
Not to be smart,but if the correct boot is used,there is NO problem to installing the boots.Most aftermarket boots are cheap junk. don
Novice 8N Owner
04-01-2001 17:02:44
 Re: Re: Replacing Rubber Boot on Shifter in reply to don b, 04-01-2001 09:13:49
Hey Don,
What's that part number, and how much are these?
You can email the response if you like.
Thanks,
N8NO
don b
04-02-2001 15:56:12
 Re: Re: Re: Replacing Rubber Boot on Shifter in reply to Novice 8N Owner , 04-01-2001 17:02:44
Part number is 8n7277...6.00 each...no boiling required. don
Ron from IL
04-01-2001 10:29:32
Not so!
I got my boot DIRECTLY from a NH dealer and it was STILL hard to install! The turning-inside-out trick works! If you grease or oil it, it's just that much harder to hold on to. I dropped mine into a cup of near-boiling water for two minutes prior to installation, and it stretched over easier, but it still took a little effort. Good luck!
Ron
don b
04-01-2001 15:14:14
 Re: Re: Re: Replacing Rubber Boot on Shifter in reply to Ron from IL, 04-01-2001 10:29:32
Just because you BUY parts from N/H,it don't make them right.Buy where ever you wish. don
Jim(MO)
04-01-2001 08:45:00
I rolled it inside out then kinda rolled back over the flange. Still wasn't easy. Read a post a little ways back that said to boil it first to soften it up and make it a litle easier.
Good Luck
Jim
boli it, and use dish soap or light oil, and grease it up
04-01-2001 09:00:30
 Re: Re: Replacing Rubber Boot on Shifter in reply to Jim(MO), 04-01-2001 08:45:00
'boli'ing' it helps to soften it. I think it's similar to boiling it. -9N'er
