Hi Al. I returned the dash. Considering the effort and additonal cost, it just put a defective dash out of reach for my means, and I located a similar dash in perfect condition through another source (for 25.00 less too). I'm glad to get your note and I have some questions if you don't mind. I printed your detailed answer to my inquiry on polishing the cast aluminum. I am very new to metalwork and I'm ignorant about materials and process. I studied the Eastwood catalog and located the materials you suggest (Tripoli Compound, 80 grit, 220, jewelers rouge and white paste etc). And I located buffing wheels. Here are the questions: Do I need to purchase buffing wheels and mount them on a motor to buff and polish the dash? Can I use a flat block and do it by hand? and what would I apply the compound to if it can be done by hand with a flat block of some type? ...what material can be mounted on a flat block? Or, am I limited to buffing wheels as indicated in the catalog? Will motor mounted wheels produce a level and flat finish? I appreciate you steering me in the right direction... A polished dash on the 9N will look great, but I want it to appear flat without undulations and scratches etc. Excuse my ingnorance, but as you suggested, this is a new adventure for me, and I appreciate the opportunity to learn in areas I haven't been exposed to in the past. Thanks in advance. 9N'er
