What should the tappet setting be
old
04-27-2005 10:13:16
May have found the trouble with one of my 8N's, pulled the head because of a valve problem and also the tappet cover. Checked the gap on all the valves and some where very tight. What should the tappet setting be cold on both intake and exhaust valves. Got them all set right now at around 15 is that about right or do I need more or less??
Thanks
Have books on other fords but not the 8N's but I also don't play with the N's much
Bob
04-27-2005 10:30:09
 Re: What should the tappet setting be in reply to old, 04-27-2005 10:13:16
Intake .012" to .014"
Exhaust .014" to .016"
These specs are from the FO-4 for COLD setting.
old
04-27-2005 10:37:21
 Re: What should the tappet setting be in reply to Bob, 04-27-2005 10:30:09
Thanks, I guess my guess was right in the ball park then.
jiminoystercreek
04-27-2005 20:03:11
 Re: What should the tappet setting be in reply to old, 04-27-2005 10:37:21
Old- I'd go ahead and take the .002 out of the intakes. Give you more power because your intake valve will be open longer.
