Crankshaft Journals
Alvin Quint
04-28-2005 11:43:30
Can anyone tell me the measurements of original main journals and rod journals on a ford 9n tractor. I need to replace bearings and can't find measurements to determine bearing size to order. Thanks
TIMW(PA)
04-28-2005 12:19:34
 Re: Crankshaft Journals in reply to Alvin Quint, 04-28-2005 11:43:30
third party image
Heres the page out of the FO-4 manual. It would be beneficial if you bought yourself a coppy. This site sells them, I got mine at TSC. I know I hated spending the $20 bucks but it is really well worth it if you own an N...Regards Tim
Bob
04-28-2005 12:11:26
Main journal 2.248"-2.249", nom 2.2485"
Rod Jornal 2.094"
Ramrod
04-28-2005 12:08:27
If you have your old bearings, look on the backside for a number, like 20. Means 20 over, for crank journals that are 20 under. I hope you kept the stuff organized so you can put all of the pieces back where the came from. Been there (not) done that.
Your maintenance manual will have the stock crank specs listed, don't have 9N manual, can't help there.
Ramrod
