PTO shaft
Raymond Frey
04-30-2005 15:13:03
I pulled the pto shaft on my 1946 2N ford and replaced the sleeve and oil seal. Now the shaft won't go back in. It hangs up on the shifter. What do I need to do? Thanks for any help.
RustyAL
04-30-2005 19:15:54
 Re: PTO shaft in reply to Raymond Frey, 04-30-2005 15:13:03
You should check the splines to be sure they did not get dented or messed up. You could have dinged them by mistake while working on the shaft.
Ray Frey
04-30-2005 19:37:54
 Re: PTO shaft in reply to RustyAL, 04-30-2005 19:15:54
You are right ,I did mess up the splines when I put on the new sleeve. I filed and debured them and it slid right in. All is well now. Thanks for your help!
JimNC
04-30-2005 17:17:09
It is probably hitting the cam block in the middle of the pump. It has a hole in it that is off center to push the hyd pistons in and out. It has dropped down a bit. If you look in the hole with a bright light you will see it. Might have to take one of the side plates off to get your hand in there and get it lined up.
Jim
