Are 601's good tractors????
9n8801
05-01-2005 09:27:06
I have a 9n now . Would not take a gold brick for it. How ever I am looking at a 601 gas burner.Some please tell me the GOOD,BAD & THE UGLY of them as compared to the 9n. What should I look for,same as I would on a 9n?
Please help me now so I wont make a BIG mistake.
Leon in N W Fl.
souNdguy
05-02-2005 05:52:28
 Re: Are 601's good tractors???? in reply to 9n8801, 05-01-2005 09:27:06
If that 6x1 has a 5 spd pto, you have a great machine.
I picked up a 660 a while back.. it is night and day difference between my 2n/8n/NAA. The 5spd is a weird alien tranny.. but works..
Soundguy
Ozbo
05-01-2005 18:36:54
The 601"s are one of the best of the old Fords. they started out as Jubilees in "53 and evolved from a darn good tractor then to a d___ good one with the "58 601"s. The last one was a 2000 in about "62. It is way yonder better than a 9n and if you get a good one, you"ll never regret it. oz
Dean
05-01-2005 12:43:02
The 6x1 tractor is much more tractor than is a 9N. Aside from about 10-12 more HP it will have live hydraulics. It will also be somewhat heavier, have larger tires, and may have power steering. Depending upon the specific model, it may have live PTO. Since the one you are looking at has a manual transmission, it is not a SOS. If it is a 5 speed, it may have live PTO. If it is a 4 speed, it cannot have live PTO.
Dean
Kevin in OK
05-01-2005 10:37:26
My grampa has one and I use it on occasion, and it is a very good tractor. Steer clear of the SOS tranny, from what I hear it is bad news. Live Hydraulics are a plus, along with a larger engine, 134 ci with OHV.
Kevin
old
05-01-2005 09:57:22
Thats a step up from a 9N probably 10-15 HP bigger. It would also have live hyds. and depending on which one it could also have live PTO. Also it could have the SOS, or 4 speed or 5 speed. If it had the SOS I wouldn't buy it but thats me, they have a lot less value. Other wise it would be about the same as looking at an N tires hyds etc
9n8801
05-01-2005 10:12:06
 Re: Are 601's good tractors???? in reply to old, 05-01-2005 09:57:22
Hi Old
Thanks for you reply. What is the SOS ? All I know about the tractor is it is red, manual trans, and is a gas burner. Need all the Help I can get.
Thanks again
Leon
old
05-01-2005 11:02:32
 Re: Are 601's good tractors???? in reply to 9n8801, 05-01-2005 10:12:06
Select-O-speed fords automatic sort of, they had proplems with them at time and are costly to repair if they have a problem. HP rateing as per Neb test is 28-37 depending on tranny. They made a number of differants ones series like the 501,601,701,801,and 901. Each was a little bigger then the other. Depending on the tranny and PTO you could be looking at say a 640,614,651,660,or 681.
ericlb
05-01-2005 10:29:25
9n8801, the sos is "select-o-speed," it was a sort of shift on the fly, semi manuel transmission, they had more speeds, but suffered massive durability problems, and very few are still working as intended, and for the broken ones praticaly no parts are available today, ericlb
