sounds like a rod knocking
8-N Nut
05-01-2005 10:31:55
What makes 'rods knock'? Thanks!
Loren,Wa
05-01-2005 12:20:48
 Re: sounds like a rod knocking in reply to 8-N Nut, 05-01-2005 10:31:55
sometimes you can fix the immediate problem, and miss what caused the problem,there are many things that can and will go wrong in a moter,ie.. low oil,contamination,tired wore out from use,improper mechanical installation,I have come across all sorts of failures,most if not all are directley associated with a lack of attention to details.so be a dectective,your moter will read like a book,you just have to understand the meaning
old
05-01-2005 11:23:52
The most common cause is running low on oil cause oil starvation to the crankand bearing.
Dell (WA)
05-01-2005 10:42:22
Nuttzie..... .....excess clearance from wear ...or... low oil pressure from thin oil or incorrect oil weight. Heavy wt oil is temporary "fixx" ...but... ultimately its a mechanical fixx commonally known as overhaul..... ....Dell
