Transmission oil to change or not to change
ricks41-9n
05-02-2005 14:10:27
I used my 9n about 20 hours last year and covered it with a tarp for the winter. I am going to change the motor oil but was wondering if you guys think I should also change the transmission oil. Thanks in advance Rick.
Upper Peninsula, Mi
05-02-2005 16:17:18
 Re: Transmission oil to change or not to change in reply to ricks41-9n, 05-02-2005 14:10:27
rick. Henry Ford recommended to change the transmission oil every 600 hours of operation or yearly. Your call. Ron
Leemo
05-02-2005 14:19:58
If there is any sign of moisture in the gear oil I'd change it. It would depend on when it was last changed otherwise. I run mine 3 to 5 years unless I need to open it up for some reason. My Ns are garaged so they don't have any water contamination and the oil seems to stay fairly clean. You'll probably get other opinions so see what sounds right to you.
Good Luck, Lee
clearfield
05-02-2005 15:32:07
 Re: Transmission oil to change or not to change in reply to Leemo, 05-02-2005 14:19:58
Take the top cover off and take a look see if it looks clear leave it alone but if it looks cloudy i would change
clearfield
Bruce (VA)
05-02-2005 16:51:04
 Re: Transmission oil to change or not to change in reply to clearfield, 05-02-2005 15:32:07
I think you mean take off the inspection covers..... ..not the top cover, right?!
