2n starter
ken powell
05-02-2005 20:23:21
1944 2n
when i go to start her up the starter kicks out as soon as she fires, and usually that means it hasnt started yet. my battery is weak and if the starter would not cut out so quickly i wouldnt have to boost it as often help and thanks
topsarg
05-03-2005 04:58:49
 Re: 2n starter in reply to ken powell, 05-02-2005 20:23:21
Put one of the new positive drives on it, there is one listed on ebay at the present time. Item# 5577472376. The new drive sure makes the removal and installation of the starter much easier to.
old
05-02-2005 20:35:24
If you know the battery is weak replace it. Its hard on the starter to use a weak battery.
Bob
05-02-2005 20:28:14
A quality, modern, starter drive will lock into the cranking position until the engine "catches" and then be kicked out. They are a great improvement over the originals.
Russ SoCal
05-03-2005 10:42:24
 Self-destructing? in reply to Bob, 05-02-2005 20:28:14
Wasn't there a post recently about them new fangled ones self-destructing?
Russ
Dell (WA)
05-03-2005 10:53:47
 Re: Self-destructing? in reply to Russ SoCal, 05-03-2005 10:42:24
yeah, 1-post about new fangled clutch starter drive falling apart ...but... about a zillion posts about old fangled Bendix drive falling apart and parts being stored in the tranny housing..... ...Dell (grin)
ratface
05-03-2005 16:30:00
 Re: Self-destructing? in reply to Dell (WA), 05-03-2005 10:53:47
I've had a positive drive bendix on for two years that Dell helped me install, no problems yet!
