Wooden wedges for clutch R+R ??
Pooh Bear
05-03-2005 18:47:24
I was reading my IT-FO4 manual about changing the clutch in my '49 8N.
It mentions some little wooden wedges are used when RR the clutch disk.
But my manual didn't say much about these wedges.
What are they for, why are they used.
Is this gonna be obvious when I take it all apart.
What else can you tell me about these wedges.
Thanks.
Pooh Bear
SteveB(wi)
05-03-2005 21:49:41
 Re: Wooden wedges for clutch R+R ?? in reply to Pooh Bear, 05-03-2005 18:47:24
Where you might want some wooden wedges is between the engine and the front axle when you do the split. Otherwise the motor can rotate on the kingpin and fall to one side.
BigGeorge
05-03-2005 19:38:14
What Dan says is correct. The pressure plate mounting bolts are only 5/16" and easy to strip out because the first 1/4" of the flywheel isnt tapped for threads. I used a 3/8" nut under each pressure plate finger, this allows the pressure plate to contact the flywheel so each bolt can be put in finger tight. Once it is bolted down tight against the flywheel the nuts will fall out..... .....BG
Paul in IL
05-03-2005 19:07:47
Pooh,
I saw that too and thought hmmmm. I have replaced a lot of clutches in my years and I have never used wooden wedges to hold the pressure plate released. I always just use a REAL input shaft and tighten the bolts evenly around the outside of the pressure plate to pull it up to the flywheel. My father did show me the advantages of taking a file to the clutch disk inside splines to allow the input shaft to slide in it easier. It only takes about 5 minutes of filing and makes a big difference in how it slides togather.
The only thing I can think of with the wedges is that it may allow you to move the disk around a little when you put the input shaft in.
I think I will dispense with the wooden wedges when I put my clutch in.
Paul K.
Dan
05-03-2005 18:58:36
The pressure plate is a spring loaded device (and very heavy springs at that). It is normally expanded to push the clutch pad to the flywheel, and you have to press the cantilevered fingers in to push back the pressure plate. The springs on these fingers are tough to push down, and you need the pressure plate retracted so you can screw the pressure plate into the flywheel. These little wedges are crammed in between the fingers and the top of the pressure plate to hold the fingers in against the springs so you can easily screw the pressure plate into the flywheel.
That said, I got mine installed just fine without them by just pressing in on the pressure plate while I started my bolts. So, they make it easier, but are not required.
Good luck,
Dan
Pooh Bear
05-03-2005 19:25:23
 Re: Wooden wedges for clutch R+R ?? in reply to Dan, 05-03-2005 18:58:36
I'm not gonna worry about them then.
Thanks.
I have replaced a number of clutches over the years in my '70 F350 dump truck. Just stick the clutch up there and start the bolts, then tighten each one a little bit all around till done. Pulls the PP springs down tight as you go.
Can't imagine it being much diffent than that.
Thanks.
Pooh Bear
