Oil pressure
Pat
04-02-2001 11:39:49
I finally got my 9N oil return line and put it on. The 9N has been sitting in my garage for the last 90 days or so and when I fired it up, no oil pressure. I looked in the archieves and saw where someone recommended pulling the oil canister and filling the housing up with oil and letting it sit. I did so and when I fired it up I had 20 pounds or so of pressure. I ran the engine for about an hour or so and shut it down several times and each time had pressure when I started it back up. This morning no oil presure again.
Do I need to rebuild the oil pump? This machine sat most of last summer and had pressure when I fired it up.
Thanks in advance guys for your advice.
TimK
04-02-2001 12:03:23
 Re: oil pressure in reply to Pat, 04-02-2001 11:39:49
Assuming you are running 30wt. or better, it appears that the oil pump is losing its prime and cannot create enough suction. But you could have developed a crack in the oil pick-up tube, which is connected to the oil pump. A small crack in that baby and you'll just suck air, no oil. If there is no crack in the tube, then sounds like time for a pump rebuild. You may want to add a quart of STP oil treatment and see if that helps before you start tearing the pan off.
