2N Brake Adjusters
Randy2N
05-05-2005 07:02:46
Hello All!
I've done a search on this in the discussion forum but didn't find anything specifically on this.
Installing new brakes on my 2N. One side is on just fine, but the other side it seems like those two short adjusting rods coming out of the adjuster to the brake shoes just aren't in as far as they should be. The brakes are extended too far to slip into the hub. The adjuster is turned out as far as it will go...meaning set for loosest adjustment. I have assembled the unit and turned the adjuster to see if they'll pop in further, but they haven't.
What's inside the adjuster? Is it suppose to "register" on the adjusting screw a certain way? Is that angled-cam that pushes on the adjuster rods a one-piece or two-piece affair?
Thanks ahead for your thoughts.
Randy2N
Jeb2N
05-05-2005 08:44:34
 Re: 2N Brake Adjusters in reply to Randy2N, 05-05-2005 07:02:46
they are just a one-piece deal that fit over a wedge inside the adjuster unit. Try spraying some PB Blaster on the outside of the adjuster where the square stud comes out and working it back and forth. I thought mine was all the way out and I eventually got another 4-5 full turns out of it using the PB Blaster. I still think I had to tap the brakes in with the wooden end of the hammer, though because it still wasn't enough to just drop in on the one side. I too had one side drop in and the other side stick.
Jeb
Randy2N
05-05-2005 17:30:07
 Re: 2N Brake Adjusters in reply to Jeb2N, 05-05-2005 08:44:34
Thanks, Jeb2N. I'll try that. After I posted I found an illustration that shows it's a one-piece. On the other side, it was too far out but then I turned the adjuster and it went "pling!" and both shoes popped in.
It shall not defeat me.
Thanks!
Randy2N
Jeb2N
05-05-2005 17:37:14
 Re: 2N Brake Adjusters in reply to Randy2N, 05-05-2005 17:30:07
Yeah, that's the other thing. Won't hurt to lightly tap the wedges and make sure that they aren't hung up as well. I would avoid spraying them with anything if you already have the new shoes installed as the spray might end up on the shoes and have bad effects.
Jeb
