NAA Rear Light Bracket Location
Ramrod
05-05-2005 13:12:32
The Old Warrior is gonna get rear lights, but there is no evidence of them ever being there before, so I wonder, where do the brackets go? Is the mounting point(s) apparent on the fenders?
Ramrod
Dan
05-05-2005 13:31:53
 Re: NAA Rear Light Bracket Location in reply to Ramrod, 05-05-2005 13:12:32
The light brackets are specific between left and right sides. Their location is apparent becuse they line up with the ridge in the fender - the bracket will have a "hump" where it lays over the ridge that will go half way into the light bracket. Because this "hump" only goes half way through the bracket, this makes it LEFT/RIGHT specific depending on which side has the "hump" opening. You will remove I believe three bolts from the fender skin to fender bracket, then re-install with the light bracket under these bolts to secure it to the fender.
Hope this makes sense, if not, email me and I will send pics.
Good luck,
Dan
Ramrod
05-05-2005 14:13:19
 Re: NAA Rear Light Bracket Location in reply to Dan, 05-05-2005 13:31:53
Makes perfect sense, thanks! How's that engine sounding lately?
Dan
05-05-2005 14:17:36
 Re: NAA Rear Light Bracket Location in reply to Ramrod, 05-05-2005 14:13:19
I haven't run it since I heard the problem - you got me scared...
I plan on removing the hydraulic pump and running the engine again to troubleshoot and hopefully isolate the problem. I know the gear on the end of the cam shaft is tight and torqued correctly, I am not sure what is loose. Just been working on the sheet metal for now until I get a good 3-4 hour window to really submerse myself in the problem without distractions.
I have been sanding the lights and evaluating my hood. Did you get the email I sent you a few days ago?
Dan
Ramrod
05-05-2005 14:36:23
 Re: NAA Rear Light Bracket Location in reply to Dan, 05-05-2005 14:17:36
I did not get your email. Looks like they're hiding email addresses on the board...
kbratton{at]cowtown{dot}n_e_t
goofed up to slow down the spammers, you'll havta make it right.
