Still a pop'n
Anonimous
05-09-2005 09:09:54
I checked the 3 and 4 wires on my 8N and they are fine and in order. I tried to set the carburator and it still didn't help the load pops. It doesn't soun like a back fire. I see flames coming out of where the exaust pipe connects to the manifold. It still has no power while plowing. It has a crack/hole in the manifold just outside the 4 cylinder. Any suggestions?
old
05-09-2005 11:02:31
 Re: Still a pop'n in reply to Anonimous, 05-09-2005 09:09:54
With that manifold like that you may have burnt valves and that would cause it to pop
Rob
05-09-2005 09:14:03
If you won"t fix that dang manifold there"s only one way to go.
Give the tractor to someone who will fix it and then every year hire him to do your plowing.
Dell (WA)
05-09-2005 09:13:45
Anonimous..... ...replace yer OLD BURNED OUT manifold with a NEW one $50 (cheap) There is some internal webbing/divider that occasionally burn out from longtime hard engine work. Causes miss-firing and loss of power. You doubt? The exhaust manifold glows at night (you won't see it in the daylite) and is actually hot enuff to light a cigarette.
Repair yer burned-out block section with HI-TEMP EPOXY. (NOT J&B Weld) check yer autoparts store for hi-temp puckey..... ....Dell
Tymoc
05-09-2005 09:13:09
Replace the manifold.
clearfield
05-09-2005 10:52:50
 Re: Still a pop'n in reply to Tymoc, 05-09-2005 09:13:09
Replace the manifold u will be amazed at how well she will run
