Tranmission fluid ford select-o-speed 800
Richard Alley
04-02-2001 19:05:36
My husband change the tranmission fluid in the tractor. In fact he took the fluid out of our allis chalmers to. He went to tractor supply and they gave him a replacement. Now neither of the hydraulics work . The arms won't even go up, without the brush hog. It calls for A TYPE TRAN. FLUID. tHEY GAVE US THE CROSS REF. So then we went to Kubota and he look it up for me, he gave me something else and it didn't work either. But we can't find the type A it calls for. Can anybody help us.
hey busdriver
04-03-2001 00:32:14
 Re: tranmission fluid ford select-o-speed 800 in reply to Richard Alley, 04-02-2001 19:05:36
I no longer own my 801 SOS Ford, but when I
changed the fluid in my hydraulics, I used the
Ford 134 oil and it did not work either, until, I
bled the pump by loosening the bleeder valve screw
and it immediately started working. I know you
state that your husband changed the oil in the SOS
transmission but in my 801 it was not the same
chamber as in the hydraulics. My hydraulics in my
801 would easily lift either end of my full size
GM 1/2 ton pick-up without trying. I am not
familar with the 800 , but I would asssume it
would be very similar .
Good luck Stan
