Throw out bearing question
Pooh Bear
05-12-2005 15:14:27
I am working on installing a new clutch in my
early frontmount 1949 8n.
I got a new throw out bearing. It looks kinda like a donut.
The old throw out bearing looks the same,
except it has ears to attach springs to it.
It had springs on it when I removed it.
Should the new bearing have ears on it.
or do I press the old one off the ears
and press the new one back on the ears.
How do I do this without damaging anything.
I can get pictures if this is not clear.
Thanks.
Pooh Bear
Hobo,NC
05-12-2005 18:17:08
 Re: Throw out bearing question in reply to Pooh Bear, 05-12-2005 15:14:27
It will knock off and go back on easy. Press would be nice but I seldom use it. Thats all you git in enny clutch kit is a bearing.
Pooh Bear
05-12-2005 18:45:55
 Re: Throw out bearing question in reply to Hobo,NC, 05-12-2005 18:17:08
Yep, tapped on it a few times and it came apart.
Will go back together real easy.
I gotta a question posted about a clutch over on the Case forum.
If you could help out that would be great.
Thanks.
Pooh Bear
damien
05-20-2005 08:41:45
 Re: Throw out bearing question in reply to Pooh Bear, 05-12-2005 18:45:55
my question is, is the throw out bearing on the inside or the outside of the transmission? and where can i purchase one, any help is greatly appreciated
Dan
05-12-2005 17:03:14
Are you talking about the clutch release bearing HUB that slides over the main drive retainer? This is the part your clutch fork pushes to move the throw out bearing into the clutch pressure plate fingers. This is not the actual throw out bearing, that fits on the end of this hub.
Good luck,
Dan
