Russell..... ...I'm so glad Michael's governor problem inspired you to ask about what you think is a governor problem inside his post where your post is not likely to be read or answered. This great N-Board does't charge for starting your very own question thread where it would probably get more immediate attention and answers. Be BRAVE, we don't byte. (grin) And while your problem could be governor related, (its way down on the list of possibles) there are 4-common runtime issues with the 4-nipple squarecan frontmount ignition system. (wheather 6v or 12v, same problem/symptoms) 1) runs for about 1-min and quits; bad condenser NOT yer stated problem 2) runs for about 5-mins and quits; clogged fuel filters (3of'em) NOT yer stated problem 3) runs for about 15-mins and quits; gunked up ignition switch guttz NOT yer stated problem 4) runs for about 1-hr and quits; restarts after 4+hr/overnite cool-off; BAD ignition coil sound like yer problem? Heres the deal; unfortunately the squarecan ignition coil is NOT as robust as we'd like'm to be. They are VERY HEAT SENSITIVE. And it takes about 1-hr of runnin' time to heat-up and MELT the insulative tars and short out the coil windings for weak sparkies, hard runnin' and poor re-starting. ...but... amazingly enuff, after cooling for 4+hrs or overnite, the insulative tars solidify and re-insulate the coil windings so it'll make good sparkies for about 'nutter hour and then it'll melt again. Do I haffta say it? Check yer ignition points gap (0.015") they're known to slip and REPLACE yer weaksister ignition coil..... ..respectfully, Dell, yer self-appointed sparkie-meister
