still running rough
Denny(ny)
05-13-2005 17:13:26
I changed coil/points/condenser/key switch/plugs-a437 gapped @ .025. still runs the same. It wont start unless I hook it to my truck then it starts raight up. Im lost.Any help is greatly appreciated!
denny(ny)
05-14-2005 04:17:41
 Re: still running rough in reply to Denny(ny), 05-13-2005 17:13:26
The contacts on the inside of the distributor cap all have a black/brown streak across the from where the rotor/electricity has passed. I had very little movement of the dist. shaft(no wobble). Spark good @ low R's-cuts out gets weak when wound up. Todays a new day.I am going to yank the card and clean it to make sure its not flooding
Rob
05-14-2005 08:17:02
 Re: still running rough in reply to denny(ny) , 05-14-2005 04:17:41
Pretty good plan. Maybe.
No response mentioned the carb and they were everyone about wiring.
Yet, you decide to work on the carb.
Interesting approach.
Good luck.
Rob
05-14-2005 04:07:18
Looks like two problems, at least. One, bad spark/running rough and that might be two problems. Second is hard starting. You need to go through the wiring from the ground strap frame connection to the starter stud to the spark plugs inspecting, cleaning dirty or corroded connections, and repairing or replacing any cracked or damaged wires or cables. All terminals and connections including the resister and ammeter. If the spark plug wires show surface cracks where you bend the wires then replace them with copper-core wires. You may end up pulling the starter back to clean the mounting mating surfaces to give a good ground. The battery and starter cables should be larger then the cables on your 12v vehicles and as short as possible. Look to see if there is an obvious difference in size and if there isn"t then get some 6v cables; they will be sold as 6v cables and don"t settle for anything less. Dirty connections and corroded or undersized cables will heat up when you crank the engine. Turn off the key and crank the engine for 30 seconds to see what gets abnormally warm. Crank the engine with the key on to check the key switch and small wire ignition system for hot spots. Be great if nothing but the starter gets warm when you do that. Get that done and get a full charge on the battery and you are ready to look for your "running rough" problem but with a little luck that goes away also.
First thing for "rough" is to swap 3 with 4 and see if that fixes it. Lot of times, you can lay a screwdriver on a plug wire and short it to ground. You may have to remove the plug wire from the plug. When you short or remove the plug wire from a good cylinder it will run even more rough or stall and there is no change when you disable a bad cylinder.
Castorriver
05-13-2005 20:46:47
I would check the positive ground connection to the frame. Mine was rusted pretty badly and the tractor acted like the starter was bad - no start condition. With a fully charged battery, the solenoid clicked but the starter didn't turn at all. When I cleaned up (sanded the rust off) the connections and re-connected everything, it cranked to beat the band. Doug.
old
05-13-2005 19:58:42
You may have a bad wire from the switch to the coil. I'd hot wire it and see what happens. Go from the battery to the coil with a wire and see if it starts, if it does you have a problem with a wire
denny(ny)
05-13-2005 18:02:32
update-I put a spare sparkie in each plug wire to see whats happening. its pretty good spark until @ very low rpm's. When I wind her up it cuts to no/intermittent spark. Its a front mount 6v.
Thanks again
Denny
Russ SoCal
05-13-2005 20:04:03
 Does not compute, does not compute in reply to denny(ny), 05-13-2005 18:02:32
"pretty good spark until @ very low rpm's. When I wind her up it cuts to no/intermittent spark."
That reads like both ends of the rpm range have unsatisfactory sparkies.
Got a voltmeter? With engine off, key on, what's your voltage at the top of the coil? Bump the engine or rock the tractor until the points either open or close. Should see readings of little over six volts (battery voltage) and about 3 volts. Also check your rotor and cap for contact abuse. How are the distributor bushings?
Russ
jwm
05-13-2005 17:29:22
Sounds like low current flow to tractor. Is your battery known to be good? Check the battery cables and make sure they are good. Disconnect them and wire brush and shine the connections. Then put them on nice and tight. James
