Sounds good, idles nice, BUT.....Starting to smoke like a smudge pot. It always had a small puff of blue smoke here and there before the carb rebuild but this is quite different. When it is idling or not under load at higher RPM it smokes a little. Put a mower on it yesterday and it started smoking like a son of a gun. Looks like oil burning to me but by now EVERYBODY is familiar with my level of expertise. A couple of things you should know about the tractor. First, it may have been abused in a prior life. In a nutshell, based on my long experience with 3 point implements and from lift arm condition....too much implement for the tractor and more than once. Second, I graded our road with the tractor before the carb rebuild and while it was not overly powerful, it did a good job and smoked little. Third, the oil in this tractor is some of the worst I have ever seen. Blacker than black. I WILL remedy this ASAP but didn't want to do an oil change for a tractor that might need a tear down until after the tear down. I could use a little direction on how to determine my next course. Is it smoking because the oil has broken down? Are the rings bad? Did I cause this fixing the carb somehow? The tractor loses power quickly after a load is added. Just need a little guidance. Thanks!
