Hupp plus Howard
RustyHulk
05-19-2005 10:51:35
Ran across an 8n the other day with the Hupp aux tranny, plus the Howard underdrive. My 8n doesn't have either and works just fine. Why do I want this other one? Wife says no anyway! Need advice about the tractor, not about the wife!
souNdguy
05-19-2005 10:56:13
 Re: Hupp plus Howard in reply to RustyHulk, 05-19-2005 10:51:35
Hupp will function similar to a sherman. It's a pre-tranny.. The Howard was a gear reduction unit for the howard rotavator ( tiller ) attachment. it lowered ground speed, but did not lower pto speed. ( It's mroe similar to an everet trencher tranny, than any of the pre-tranies that lower or raise ground speed AND pto speed. etc. )
Soundguy
RustyHulk
05-19-2005 11:31:24
 Re: Hupp plus Howard in reply to souNdguy, 05-19-2005 10:56:13
Thanks for the information. I think I will buy it and hide it behind the shop. Just have to make sure I don"t park the 2 n"s side by side. The guy that owns it couldn"t get it to run a five-foot brush hog very well. Sounds like either a tired engine or the Hupp was in high gear. I"ll find out tomorrow. Should there be any extra gear noise or anything else to look out for? Rusty
souNdguy
05-19-2005 11:36:05
 Re: Hupp plus Howard in reply to RustyHulk, 05-19-2005 11:31:24
I find that pre-trannies tend to add some gear noise, especially in overdrive.
The howard is surprisingly a very small set of parts.. and I wouldn't look to hear anything from it.. if you did.. I'd think there was a major problem.. etc.
Test the haoward to see if it engages, etc. In fact.. drive in all ranges, and speeds.. etc.
Soundguy
Pitch
05-19-2005 16:21:57
 Re: Hupp plus Howard in reply to souNdguy, 05-19-2005 11:36:05
If you do get it, just remember that the Howard is only there to slow the ground speed. DO NOT attempt to pull with it it is not a granny gear. That is the reason that Howards are reffered to as fragile. Folks tried to use them as a granny gear and tore them up. Parts are no longer available.
