Order Ford 8N Parts Online
High lift on 8n
paul
04-03-2001 19:31:45
i bought a high lift minus the pump,shaft,and control valve for a 8n.This lift has a plate that is supposed to bolt onto the under side of the frame but there are no bolt holes on this tractor.The lift is a Masey and I was told it would mount on this tractor.My Question is do I have to make brackets off the front end to mount this type lift or am I missing something? Also is there a way to hook up and run the lift and use the same control as the rear lift?If so where do I hook into the body of the tractor? If not do I need a front pump then run lines for a control valve? I am new to this tractor business and all the things that go with it, so I will appreciate all the help I can get
