white crud in oil tube
A. Jones
05-22-2005 19:31:44
I have an 2n, today I pulled off the oil tube( im not sure what it is called). When I looked in it, the walls were covered in a white crud. Is this normal or does this mean I have a problem?
thanks
Russ SoCal
05-22-2005 21:37:41
 Re: white crud in oil tube in reply to A. Jones, 05-22-2005 19:31:44
AJ,
As long as your dipstick doesn't look the same, you don't have a problem..... except..... I'll bet your tractor doesn't have a job. The white stuff is water condensation and the engine needs to get hot enough to evaporate it, and as Rob pointed out, if the oil fill tube cap is gunked up, it makes it twice as hard.
Russ
Rob
05-22-2005 20:07:52
That breather cap element is probable shot. You might find an element or you may have to replace the entire cap.
