1st Oil Change -- Plug Filter
Plus PICS!!!
Andy - Hammond,
04-04-2001 10:14:38
third party image
I just got around to my first oil change since buying my tractor a few weeks ago. Yes, I am in pamper city here. The oil was in need of changing and the filter is very confusing. Is this an ORIGINAL OIL FILTER? It sure does look like it to me - but of course I don't know any better. check out the picture. Also, I read in the I&T manual that the drain plug should have a screen on it and the one I took off does not. How important is this screen on the plug and do I need to replace it or the whole plug or nothing? I replaced the oil with HD SAE30WT name-brand oil and new Napa 1010 Gold Filter. Is this suitable oil/filter for my warm summer weather? I am in LA - lowest temps we get are around 20-25 degrees F in winter - mostly around 30-40F. Maybe I will switch to a multiweight oil in the winter.
third party image
third party image
Look at the pics - the numbers on the filter should be visable on the pics -- pretty cool looking in any case! Also check out my new knobs and proofmeter decal! It is coming along nicely!
third party image
third party image
Thanks to this board!
Andy
ED
04-04-2001 12:44:51
 Re: 1st Oil Change -- Plug Filter - Plus PICS!!! in reply to Andy - Hammond, LA , 04-04-2001 10:14:38
That is a pretty old filter - how did it end up in a tractor so new looking? I saw one of those on EBAY once, still in box! It brought $50.00.
By the way, I use a FRAM C3 filter. Similar looking but no orange paint and a rubber gasket on the top.
Hey Andy in Hammond..................
04-04-2001 11:47:46
....did you ever find anything for that tractor to pull around?
Todd in Denham
NO -- WHY DO YOU HAVE SOMETHING I CAN PULL AROUND?
04-04-2001 12:02:14
 Re: Re: 1st Oil Change -- Plug Filter - Plus PICS!!! in reply to Hey Andy in Hammond.................., 04-04-2001 11:47:46
Hey Todd --- I need a bushhog 5' -- have you seen any around here - I dont want to buy brand new unless I have to but let me know.
Andy
Novice 8N Owner
04-04-2001 12:40:03
 Re: Re: Re: 1st Oil Change -- Plug Filter - Plus PICS!!! in reply to NO -- WHY DO YOU HAVE SOMETHING I CAN PULL AROUND?, 04-04-2001 12:02:14
No..... I don't know of any at this time. I just remember you saying your wife was curious if you ever were going to use the tractor for any work(or something to that effect). My wife thought that was pretty funny. I just don't understand females! :)
TM
Brad
04-04-2001 11:08:43
hi Andy,are you talking about the drain plug on the bottom of the pan?if so why would a screen be needed on the bottom?help me out i am about as big of a begginer as they have around here...trying to soak up as much info as i can,the guys on this board are full of great info...
bj/8N/mt
04-04-2001 11:16:59
 Re: Re: 1st Oil Change -- Plug Filter - Plus PICS!!! in reply to Brad, 04-04-2001 11:08:43
take a look at figure FO24 after paragraph 21 in the I T manual
the oil pump pickup rests on the screen
running without the screen invites vibration in the pickup and eventual seperation which cannot be good
at twenty bucks for a plug with a screen I wouldn't run without it---but
your mileage may vary
ED
04-04-2001 11:16:01
The screen is in the shape of a cylinder and serves to filter out large particles in the oil. The oil return pipe discharges into this screen cylinder. Then, when you open the plug, the large trapped particles are removed.
Claus
04-04-2001 10:49:41
First, I would like to say...Real nice looking tractor. I do not know what an original Oil Filter is, unless you are talking about the one furnished with the tractor when it was sold new. This one appears to have been made by Fram for Ford. The filter you purchased, (NAPA 1010) is a good replacement filter. As far as the screen is concerned, I would buy a new plug (They come with the screen) especially since HD oil may break off sludge crud that may be there if the tractor was run with non detergent oil for long periods of time. If you know that the pan is clean and does not have accumulation of crud then the screen is not that important.
Happy Motoring
Claus
