Not anymore than a bad rear tire would. Like I said.. the chargeing and ignition systems are all but seperate systems. At very worst, if the coil secondary was shorted to ground, the tractor wouldn't run.. but even with that.. there would only be a 3 or 4 amp draw.. as if the key was on and points closed. Also.. if the primary was shorted to ground, the tractor would not run.. and the wire tot he coil primary would burn in half in less than a minute.. In both cases.. no tractor ignition.. same with an 'open' coil... Looking at that.. yes, if the tractor won't run, then yes.. the coil could keep the tractor from charging...if the tractor will run.. then no.. the coil has -0- to do with the charge system, like I said in my previous post. Sounds like you really really want to spend the 15$- 30$ to change the coil since you've asked about it twice, in connection with the charge system. If that's what you are aiming for.. go change the coil.. then come back, and fix that unrelated charge system problem... Soundguy
