Pulling a 2N that wont turn over
6N's Short
05-27-2005 06:24:50
Here I goes, demonstrating my lack of mechanical knowledge again. After I have tried all the great advice this weekend from my previous post....
If I decide to pull the 2N with one of my other iron monsters, is there a procedure to follow so that I don't break something else?
And....Dell, I have thought about it and I don't know why everything electrical runs on smoke. Whazup with that? :-)
don t.-9n180179
05-27-2005 09:38:29
 Re: Pulling a 2N that wont turn over in reply to 6N's Short, 05-27-2005 06:24:50
I aint Dell, but I know anytime I've screwed up electric "stuff" I usually see smoke comming from that area. And ofcourse it don't work no more.
HTH....don t. ....
Rick H. Ga.
05-27-2005 09:57:50
 Re: Pulling a 2N that wont turn over in reply to don t.-9n180179, 05-27-2005 09:38:29
That is called "letting the smoke out of it". If you "let the smoke out of it", like Don T said, it don't work no more:-). Rick
Bruce (VA)
05-27-2005 06:56:41
The only thing I can add to what Rick sez is get a long tow rope/chain, and it will probably take 15-20 seconds or more before it will fire; it is not going to fire as soon as you let the clutch out (in 4th gear, as Rick said). Do not pop the clutch. Just ease it out.
Rick H. Ga.
05-27-2005 06:48:40
I have pull started my 49 8N several times over the years. There should not be a problem as long as nothing is locked up or knocking. You have to have two people, of course.
The key is to make sure the tractor being pulled is in high gear, ignition switch is on, gas bowl valve is open and you have some breaks.
If you try to pull it in low gear the back tires will just skidd on the ground.
Pull starting a tractor is a last resort to get the thing cranked.
Good luck with it. Rick H. Ga.
