I punctured my rear tire on my 53 Golden Jubilee. The treads are deeply weather checked and about 50%. The punctured tire worked itself off the rim on the inside.So, I've decided to forego a repair and get a set of new tires for the rear. Since I've only owned my tractor for about 6 weeks I thought I'd ask for advise on brand, type, cost, etc. I'll be using the tractor to clear land and build some access roads. I'm using a 2 bottom plow and a back blade. Terrain has many thorns, 1/2" to 1" tree stumps/stubs, and rocks (some jagged). I've seen 8 ply tires and these seem like they would provide extra resistance to punctures. I have also seen some sort of tire 'inlay' or sleeve made of rubber to give another barrier between the inner tube and the tire...any thoughts on these? I take it size should be 11.2x28? How about 12.4x28? I am looking for an Ag R-1 tire. Is this correct? Any advise would be appreciated! Thanks, Paull.
