I wish I could say the I"ve just finished a rebuild of my mother"s 2N but I"m afraid I"ve got a bit more to do. With a new piston /sleeve kit, new adjustable valves (and new exhaust seats), and a skim of the head and deck, I"ve only got 75,90,90,60 psi compression. Those numbers change to 95,98,98,85 with a squirt of oil. I figure where I went wrong was in one of two places. First, the ring end gap was .016-.018 across the board when I checked them before installation. I asked the machine shop who supplied the kit and did the heavy work for me if that was too large since the book calls for .007-.012. They said that it should be fine. I also read somewhere that a service limit of .035 was acceptable?? I did not hone the new cylinders, they were between .002-.003 on the skirts and had a decent crosshatch, and I didn"t want to open the rings up anymore. I would have liked to get the crosshatch deeper but I held back. The other thing that is nagging me is that they suggested that I grind the cam to go with the new lifters. I wonder if the lobe centers are off now adding to the ring problems. Has anyone had a similar experience? I will look into oversized rings and possibly check the cam timing. To me, the compression test points to rings. Is there something else that it might be??
