select o speed
Reno J.
05-31-2005 09:41:50
Looking at a 3000, It has a select-o-speed tranny.Ive heard to stay away from them. whats the scoop on them? junk? thanks.
Eric ATL
05-31-2005 16:03:47
 Re: select o speed in reply to Reno J., 05-31-2005 09:41:50
Reno, SOS, what a controversial subject. Search the archives for "SOS" you'll get more than you ever wanted to know. You will need to filter out personal opinion and make your own judgment based on peoples actual experience. I have a 59 801D with SOS and I love it. It all depends on how well it has been maintained. Don't run away yet. It may be in fine condition and you may be able to bargain down due to all the bad rap the SOS gets. If it doesn't operate properly then you can research it further to try to determine if it's a costly fix or not. If it doesn't work right and you're not sure then you can run. HTH, Eric
hvw
05-31-2005 10:45:17
The scoop is that unless it has been properly maintained it will almost surely need very expensive and difficult repair. Parts hard to come by, can't be readily swapped for a 4 or 8 speed. Will not bring near the dollars at resale as the manual transmission. As someone once said on the Ford Board, "don't walk away from it...run"
Rob
05-31-2005 10:42:15
Here is some stuff.
