Order Ford 8N Parts Online
8n oil stupid question
psmart
06-01-2005 07:05:18
Hey just bought a 8n and it is alittle low on oil at dip stick. Where is the oil fill??? Do you fill at the dip stick ????? ?
Bill in WI
06-01-2005 08:02:05
 Re: 8n oil stupid question in reply to psmart, 06-01-2005 07:05:18
Same as what Steve said, but replace all the "Right's" with Left.
Steve (Magnolia, TX)
06-01-2005 08:03:49
 Re: 8n oil stupid question in reply to Bill in WI, 06-01-2005 08:02:05
Ya, I meant that "left" right.... Ooops...
Thanks, Bill
Steve
John in Bama
06-01-2005 07:53:24
Pour engine oil in at the crankcase breather. Just pull it out and dump oil in. If you just bought it, change all fluids. You don"t know what is in there. 8N - 6qts engine oil. Everything else is the 5 gallon deal.
Oil filter is NAPA Gold 1010.
Clean and replace oil at air filter. Doesn"t hurt to pull and clean air filter element either.
06-01-2005 07:22:01
Just to the right of the dipstick (assuming you ARE checking the crankcase dipstick? There's a hydraulic sump dipstick on the right, under the seat, too) is a tube, about 1.25" in diameter with a large (~3") cap on it. Pull the cap. Dump in the oil.
If it's the hydraulics that you're looking at (the dipstick under your seat), then the fill is what looks like a large nut on top of the transmission cover, to the right of the gear selector and to the rear of the starter switch.
HTH
Steve
