6v at battery, 3.5v at the coil is about normal, and looks ok. Do go ahead and check the points, just make sure they aren't burnt. With the correct voltages and resistor in line.. the coil and points should be ok. I doubt the 8v battery damaged the coil in that short of time. I'd look for other things. Next time it stalls.. try jumpering past your key switch, if it is an old switch.. if this helps, then you may have a bad switch, making for weak spark. You might also pull a plug wire and see what color spark you have.. blue is good.. orange is bad. Another thing to check is next time it stalls.. if spark is good.. pull the drain fromt he carb and see if you have a good continous fuel flow.. if not. check the fuel system. There are few things that take that long to manifest.. though i guess coil could be one.. Geerally when the coil quits.. it takes a while to cool before you can restart... Fuel flow ont he other hand.. if it were blocked.. enough could leak intot he bowl to get you going again. Have some starting fluid handy.. see if it will start on starting fluid, then stall.. or keep running on gas after that. After you do these tests.. check back. Soundguy
