Order Ford 8N Parts Online
8N-torque specs on engine rebuild
Phil ARROYAS
06-05-2005 18:42:48
Could anyone confirm the torque specs on a 49 8n for the rod bearings, main bearings and head gasket bolts. Thanks, Phil
Dan
06-05-2005 19:18:45
 Re: 8N-torque specs on engine rebuild in reply to Phil ARROYAS, 06-05-2005 18:42:48
Here is a good sampling, but the I&T manual is more thourough:
~Engine~
Main Bearing Cap Bolts 95-105 ft.lbs.
Water Pump to Cylinder Block 15-18 ft.lbs.
Camshaft Thrust Plate to Cylinder Block 10-16 ft.lbs.
Oil Pan to Cylinder Block 15-18 ft.lbs.
Camshaft Gear to Camshaft 45-50 ft.lbs.
Oil Filter to Cylinder Block 20-25 ft.lbs.
Carb Throttle Body to Fuel Bowl 36 in.lbs.
Oil Pump to Cylinder Block 30-35 ft.lbs.
Connecting Rod Nuts 45-50 ft.lbs.
Oil Tubes to Oil Pump Cover Plate 10-15 ft.lbs.
Connecting Rod Pal Nuts 3-4 ft.lbs.
Rocker Arm Shaft Bolts 45-50 ft.lbs.
Crankshaft Pulley to Crankshaft 100-110 ft.lbs.
Spark Plugs 24-30 ft.lbs.
Cylinder Front Cover 15-18 ft.lbs.
Valve Push Rod Chamber Cover 20-30 in.lbs.
Cylinder Head Bolts 65-70 ft.lbs.
Valve Rocker Arm Cover 8-10 ft.lbs.
Flywheel to Crankshaft 75-85 ft.lbs.
Valve Rocker Arm Support to Cylinder Head 45-50 ft.lbs.
Manifolds to Cylinder Block 40-50 ft.lbs.
36 in.lbs.
Governor Cylinder Front Cover 15-18 ft.lbs.
Governor Case to Front Cover 6-10 ft.lbs.
Good luck,
Dan
Tom in MS
06-05-2005 19:09:50
Link
