Jubilee Wiring
Robert May
06-06-2005 16:44:49
I have a Ford Jubilee Tractor with the original 6 volt battery and I would like to know if 14 gauge wire will work for the head lights?
Also, does any one know where on the internet that I can find a copy of the orignal wiring digram.
Thanks.
Bob
Dan
06-06-2005 19:03:11
 Re: Jubilee Wiring in reply to Robert May, 06-06-2005 16:44:49
third party image
From the myoldfords.com website:
Good luck,
Dan
Bob May
06-10-2005 12:20:43
 Re: Jubilee Wiring in reply to Dan, 06-06-2005 19:03:11
I will consider this information.
Thank you.
Bob
Ramrod
06-07-2005 06:19:02
Notice that the power for the lights comes through the ignition switch. I think that could explain why so many ignition switches fail. I have a NOS original ignition switch on Old Warrior, and a new wiring harness. I have added a relay that pulls directly from the battery through a fuse link to power the headlights. The relay coil is controlled by the headlight switch, which is fed through the ignition switch so it will only operate with the key on. I will add another relay for the rear work lights, and I'm betting that my NOS ignition switch will last a very long time.
Ramrod
ZANE
06-06-2005 18:11:23
Check out the site below/
Zane
Ramrod
06-06-2005 17:06:12
A 14 gauge wire will safely carry 15 amps. To figure max power allowed for the two headlights, 6 volts times 15 amps times 2 headlights equals 180 watts max for your combined headlight bulbs. If your bulbs are less than 90 watts each, it'll work just fine. Be sure to run a ground wire to each bulb, don't count on the internal ground jumper wire.
Ramrod
Jim.UT
06-07-2005 11:51:37
 Re: Jubilee Wiring in reply to Ramrod, 06-06-2005 17:06:12
6V tractor headlight bulbs are typically about 35 watts each. At least the sealed beam ones are.
