Dash Bolt Question
Anonym
06-07-2005 08:25:17
Well, my 1947 8N had her maiden voyage last night after sitting the majority of a year while I fixed her up. It looks like I'm going to need some front bearings and an adjustment in the carb (runs best at half-choke), but other than that, she looks and runs pretty good!
I had a post a few weeks back on a damaged steering column shaft and ended up ordering a die to rethread the damaged end and everything went on great. I did have some issues with the new paint not grounding my headlights, but a second line back to the battery ground took care of that problem as well.
Now on to my question. The 4 bolts that mount the dash and hood together don't want to go in very smoothly and I was wanting to get some nice stainless bolts anyway, but I can't seem to find a size reference on them anywhere. Do any of you know the size/threading/length of these?
As usual, your help is much appreciated! Pictures will come as soon as I mount my tail light and implement light.
Thanks,
Justin
jiminoystercreek
06-07-2005 15:51:53
 Re: Dash Bolt Question in reply to Anonym, 06-07-2005 08:25:17
The original are better, in light of the difficulty you're having with the old ones. If you think the old ones are giving you a problem, the stainless will have you pulling your hair out if they get gaulled up by not so perfect nut threads.
BTW- the two bolts that hold the air cleaner bracket on are also chrome plated.
We anxiously await the pics!
Dell (WA)
06-07-2005 08:36:10
Justin..... ...the domehead dash bolts are p/n 355494-S8, 3/8-24x0.84" hexbolt. 3/8-24 is FINE thread. S8 means Zink plate. But I always thought my dashbolts were chrome plated. Dashbolts are still available from N-Tractor parts speciality houses..... ..Dell
Anonym
06-07-2005 08:51:53
 Re: Dash Bolt Question in reply to Dell (WA), 06-07-2005 08:36:10
Ahh, thanks Dell! Much appreciated. I'll pick a couple up this afternoon.
Thanks,
Justin
