Stonerinpa
04-06-2001 07:49:08
Re: Will 2N pull these implements? in reply to Paul in VA, 04-05-2001 20:30:43
Paul, from my experience, here is my 2 cents worth. A hay rake of any kind should be of no problem, unless it is a pto rake, and then you might need to have a few modifications such as pto adapter etc. I am not familiar with that particular baler, but if it is a pto baler, I would not recommend it with a 9-n. Having said that, years ago, I baled a lot of bales with a 9-n and pto baler, but it is not a good idea. You really need a live PTO to bale. If that J>D> disc is an offset disc, I would forget even thinking about pulling it. A regular 8 foot disc would be an awful lot for that tractor. An offset disc really pulls hard when you have set it to cut the way they are designed to do. Again, years ago, my neighbor had a 6 foot offset disc, and it was more than my 9-n could handle. As to the mower. I have a 501 mower, and they are a nice machine. However, it takes a few extra attachments for a 9-n because of the way the hydraulic works on them. You really need a live hydraulic. At the very least, a position control is really important, and even the infamous Zane-Thang that you see talked about on this board would not be a satisfactory alternative. (yes, I have one). Good luck at the sale!
