Sheet metal front grill and dog legs
RBCanada
06-09-2005 02:37:47
Can someone tell me the distance between the two dog legs (side panels) near the lower mounting bolts? My front grill and one of my side panels are damaged in this area. I am trying to re-fit the grill into it"s original location but I am not sure of the exact spacing or clearances that should be there at the lower part of the tractor. Thanks RB
Rob
06-09-2005 06:29:08
 Re: Sheet metal front grill and dog legs in reply to RBCanada, 06-09-2005 02:37:47
You might try using spacers like wood wedges to fit the doglegs around the grill. Or just measure or git it to where is looks right. Watch the radiator cap and the spacing above the oil filter when you make that lower dogleg attachment. I"ve seen where guys got it wrong and they had trouble with room to pull the oil filter cartridge. You can also end up rubbing against the radiator cap or throat. A lot depends on how you get everything lined up and attached down there.
That axle/hood/radiator support gets bent after bumping trees and it throws everything out of alignment.
