6 volt coil batt / field vs + /-
Roger in Norcal
06-11-2005 17:38:35
I just purchased a new 6 volt coil. The old coil is marked batt / field. Terrific. The new coil is marked only + and -. The question is: If the electrical system is positive ground, then the hot wire goes to the negative terminal and the positive to the distributor??? or vise versa?
I'm so conflicted!
Dell (WA)
06-11-2005 17:53:10
 Re: 6 volt coil batt / field vs + /- in reply to Roger in Norcal, 06-11-2005 17:38:35
Roger..... ..the rule is (+) to (+) meaning the coil plus connects to the battery plus. Since yer sidemount 8N should be positive ground, thats what that big flat braid is supposted to be connected to the battery positive (+) post; that means yer new roundcan ignition coil (+) connects to the ignition points which are GROUND. ...ie... (+) to (+) Simple, eh?..... ....respectfully, Dell, yer self-appointed sparkie-meister
Roger in Norcal
06-11-2005 18:16:51
 Re: 6 volt coil batt / field vs + /- in reply to Dell (WA), 06-11-2005 17:53:10
Dell- as always, much appreciated.
