Drag Link Question
Novi
06-14-2005 14:31:12
I'm trying to install the drag link, but I can't put the front end nut on. The threaded part keeps turning in the link end and I can't hold it while I put the nut on. Any suggestions?
Thanks
9NJoe
06-15-2005 12:17:50
 Re: Drag Link Question in reply to Novi, 06-14-2005 14:31:12
Novi,
Use an impact wrench, the inertia will keep it there until it socks up.
Joe
souNdguy
06-14-2005 20:12:33
Ditto what bob said.. try to seqt the end int he socket.. vicegrips work great.. so does a c-clamp.
Soundguy
Rob
06-14-2005 15:14:12
Get the other end stationary, reach back about a foot or 18" and pull it into the socket. You can get good leverage on it and hold it in there so it won"t turn so easy.
BOB061
06-14-2005 15:04:02
If you have a die or a thread chaser clean up the threads or some times you can squeeze the tapered stud into the arm with pliers or a clamp to hold it untill tight.
