Order Ford 8N Parts Online
Troubleshooting 8N Ignition?
Alan R
06-16-2005 08:31:20
I recently acquired a 52 8N that supposedly overheated about a year and a half ago and would not start after that. Because a few parts had been removed, I replaced the coil, points, plugs, condensor, rotor, starter solenoid and battery (along with cleaning up the carburetor). When I attempt to turn over the engine, I get nothing at all. No click no spark. When I jump the battery directly to the starter, I can get the starter to turn. Until I can get a manual, can anyone provide a quick step by step troubleshooting procedure to help me track down the problem? Thanks for any help.
Dell (WA)
06-16-2005 13:46:12
 Re: Troubleshooting 8N Ignition? in reply to Alan R, 06-16-2005 08:31:20
Alan..... ..there ain't NO line-item check list like "trouble shooting for dummys" for trouble shooting the SIMPLE 8N ignition system. Remember, 8N's were designed for horsefarmers, you can operate a computer.
The OEM 3-terminal starter solenoid is internally electrically HOT and operates by GROUNDING the thumb switch by the tranny shifter. Its not uncommon for the little hard to gitt-too middle terminal wire to break. Simple test; ground the screw at the BIG thumb switch. Solenoid operate? problem is INSIDE yer tranny shifter. NOT operate, problem is wire to tranny starter switch. (maybe?) NEXT, ground the middle terminal with a screwdriver blade 'cuz its handy. Starter solenoid operate? definate problem with wire to thumb switch. See how simple that is, eh?
Iff'n Solenoid don't operate by grounding the little middle hard to gitt-too screw. Problem is the most likely the BIG BATT WIRE (-) terminals invisable CORROSION. Remember the 6-volt MANTRA: "keep'em clean, bright, and tight". And don't be fer usin' wimpy furrin made battery cables. Gittcha summ 'arry-chested 'murricum made one-ought (1/0) thick as yer thumb battery cable.
As a general rule, you've replaced all the suspect ignition system ...but... even new parts can be bad. I'd "polish" invisable corrosion off'n the ignition points by sliding a strip of brown paper bagg thru the closed points. Can find a paperbagg? Use a dollar bill. Simple, eh?
Remember, iff'n you "flood" yer engine, you need to replace even yer new sparkies with brand new sparkies because modern no-lead gasoline leaves invisable deposits on the center insulator and them lazy sparkies will leak-off and NOT JUMP the 0.025" sparkie gap. Always check the gap even on brand NEW SPARKIES. AutoLite AL-437's are recommended.
As for why the PO couldn't gitt the OVERHEATED engine to restart; probably warped the cylinderhead, blew out the headgaskett and LOST COMPRESSSION. Smart thing to do would be to do the dreaded compression test. Ford specs: 90psi min (dry). Do 5-puffs min and writter down. Then do a WET, 5-puffs min. Squirt about 1-oz (tablespoon) of engine oil down the sparkie hole. Oil will seal yer piston rings and up the compression over dry. Amount of PSI increase is indicator of engine condition. +10psi, good engine; +20psi worn good engine; +30 tired engine: +40psi really tired engine; NO INCREASE burned exhaust valve or BLOWN HEADGASKET. Simple, eh?
You don't wanna do a compression test? Squirt some oil down the sparkie hole ennyways 'cuz the piston rings have lost their seal just sittin' thar. Engines with NO COMPRESSION DON"T START. Simple, eh?
Recommend you consider the merits of having your very own personal copy of the I&T FO-4 manual. $22, (cheap). Readily available from sponsors of this great N-Board. Most agricultural emporiums. amazon.com, BordersBooks, WalMart books. www.n-news.com also has great archive of implement manuals. Heck, even Ford/New Holland dealers sell it, isn't that amazing? Even my local (byte my tongue) John Deere dealer parts counter has it for sale. Gittcha one and readitt..... ...respectfully, Dell
Dan Hill
06-17-2005 03:28:13
 Re: Troubleshooting 8N Ignition? in reply to Dell (WA), 06-16-2005 13:46:12
Gas and oil fouled plugs can be cleaned by soaking in a covered jar of lacquer thinner.Ive done it for years.I keep a small jar in my chain saw tool bag.When a plug fouls I drop it in the thinner for a while.
Dell (WA)
06-17-2005 06:02:45
 Re: Troubleshooting 8N Ignition? in reply to Dan Hill, 06-17-2005 03:28:13
Dan..... ...you are right about using a "solvent-soak" to clean oil fouled sparkies. People with invisable no-lead fouled sparkies don't want to wait for the solvent to clean their sparkies, they just want to gitt their tractor runnin, NOW! That is why I recommend to ALWAYS have a spare clean set of sparkies on hand to change to. $10 (cheap) After I gitt the engine runnin', I'll then clean 1-sparkie attta time in a HOT RUNNIN' ENGINE. It only takes a few minutes to change sparkies. Engine runs pretty good on just 3-cylinders and when the 4-cylinder with the dirty sparkie kicks in, you'll know about it. And then it's time to swap out 'nutter dirty sparkie for cleanin'..... ..... respectfully, Dell
Buss
06-16-2005 09:31:49
I had the same problem when I installed a new solenoid. Found out that the inner most nuts on the studs on the solenoid were not tightened at the factory. Worked fine after tightening these about a turn.
Bob
06-16-2005 08:54:30
The old Fords use an unusual system (by today's standards) for the starter solenoid. Instad of needing battery voltage applied to the little terminal on the solenoid to kick it in, in this system, the solenoid kicks in when the little terminal is GROUNDED by the tranny-top interlocked safety switch.
If you have a solenoid not specifically for the older Ford-style application, it will not work.
If you do have the correct solenoid, one specific large stud must be connected to the battery for it to work, as this stud is internally connected to one side of the solenoid coil.
Alan R
06-16-2005 09:01:42
 Re: Troubleshooting 8N Ignition? in reply to Bob, 06-16-2005 08:54:30
So are you saying that I could have put the solenoid on backwards? If so, I could try reversing it, but that would put the small terminal to the outside, rather than facing the engine block? By the way, it is the correct solenoid specifically for the tractor. Thanks for the reply.
Bob
06-16-2005 09:13:03
 Re: Troubleshooting 8N Ignition? in reply to Alan R, 06-16-2005 09:01:42
Check with an Ohmmeter, with all wires removed from the solenoid.
If it is the correct solenoid, there will be continuity between ONE of the large studs and the small terminal. The other stud will be isolated from the other two.
The battery cable gets connected to the stud with continuity to the little terminal. The starter connects to the terminal isolated from the other two.
Alan R
06-16-2005 09:48:55
 Re: Troubleshooting 8N Ignition? in reply to Bob, 06-16-2005 09:13:03
Thanks for the info. I'll check out the solenoid in detail and let you know what happens next. If this doesn't solve it, where should I look next?
souNdguy
06-16-2005 10:50:19
 Re: Troubleshooting 8N Ignition? in reply to Alan R, 06-16-2005 09:48:55
Bottom line.. OEM 3 terminal solenoid.. small terminal faces block.
Ground the small terminal to energize the internally hot solenoid.. if that doesn't do it.. you have hooked it up wrong somehow.. or it is defective.
Soundguy
Alan R
06-16-2005 11:03:15
 Re: Troubleshooting 8N Ignition? in reply to souNdguy, 06-16-2005 10:50:19
Thanks for the reply. I'm trying to line up a few tests for this evening. So far everyone has focused on the solenoid, but what I was hoping for, was a step by step check out of the entire ignition system, since the tractor conked out over a year ago for unknown reasons. I'm not too good with electrical systems, so was hoping to find a simple guide to following the current and (hopefully) finding the problem(s) along the way. Can anyone describe such a step by step checkout procedure or point me to a manual that does? Thanks again.
Rob
06-16-2005 18:04:03
 Re: Troubleshooting 8N Ignition? in reply to Alan R, 06-16-2005 11:03:15
The Ford 8N Operator"s manual has a step-by-step procedure to isolate ignition problems. Don"t even need a meter and takes maybe 3-minutes, unless you"ve got it memorized then it takes half that long.
It also has a simple to understand procedure to check out the starter system, which is your problem.
FYI, the 3rd part of the electrical is the charging system which is also in the manual.
You get the manual from your local Case/New Holland dealer. I got one for $5.
souNdguy
06-16-2005 11:16:37
To borrow a quote from fellow list member Dell. " Follow the volts".
get a test lamp or VOM.. First.. get your solenoid issue fixed.. with 3rd terminal facing block, and 'right side' terminal hooked to battery negative ( positive ground system if it is 6v pgrnd system ), and the transfer bar hooked tot he starter.. with a good charge ont he battery.. grounding that 3rd terminal will energize the solenoid.
Now.. you will be able to follow a wire diagram for power. Use test lamp or vom to check power at ignition switch..move over to the coil.. should see power at the incoming primary side.
For front mount 6v units.. when you turn the engine over, voltage should 'bob' from battery votls to ( 2.5-3.5 ) and then back. Basically when the points close.. the votlage drops.. when they open, battery votls again. if a side mount.. voltage should go from battery votls to 0 volts on a 6v unit.. or a 12v unit and 12v coil.
Now.. when the points open is when spark happens.. if front mount.. use a spare plug.. frounded, and spin engine over.. you should see spark.. that's about the 'best' test of the ignition system you can do.
If you don't ahve power at the switch or coil. go back up the line till you do.. then isolate the problem
Soundguy
Alan R
06-18-2005 11:37:18
 Re: Troubleshooting 8N Ignition? in reply to souNdguy, 06-16-2005 11:16:37
Finally found some time to check things out today. So far I"ve found that as Soundguy described, when I ground the small solenoid terminal the starter bumps over. I"ve also found that there is current to the switch and to the coil. However, I still cannot get the starter to spin by using the start button. The start button wire is frayed near the button and I don"t get any voltage there with or without the switch on. I took the regulator out and opened it up. The contacts look clean, no obvious issues there. Looks like I will need to get that manual as soon as I can to go any further. Thanks to everyone for the help so far.
souNdguy
06-18-2005 12:04:29
 Re: Troubleshooting 8N Ignition? in reply to Alan R, 06-18-2005 11:37:18
There will be on 'current' at the oem thumb start button the8n uses.. it is merely a button that grounds the small terminal from the starter. Pushing that thumb button is the same as taking that small third terminal and touching it to ground.
I'd use your ohmmeter, and disconnect the wire from the switch ( and solenoid ...for safety.. ), and then measure from the switch button to ground.. push the button.. i f the ohm meter doesn't indicate a short.. then your thumb switch is bad.. or the tranny is in gear.. etc...( that switch is tranny interlocked.. won't depress fully if the tranny is in gear.
Soundguy
