If the pump has a problem, or just never primed, pulling it around for that long with no oil pressure can "toast" things just as quickly as if it were running. The bearings need a steady flow of lube! If no oil pressure in less than 1/2 minute of running, or pulling it, it's time to stop and find out what's wrong before damage is done. An old hot-rod engine bulider's trick is to use an external source of pressurized oil to fill the oil galleries, prime the pump, and lube the bearings, before the engine is ever started. You can use a NEW, clean, pump-up garden sprayer that will cost $10.00 to $20.00 to make a simple system to do this. Simply cut off the plastic wand ahead of the nozzle. Get a brass hose barb that will screw into the oil gauge fitting at the back of the block. Connect the cut off wand and the brass fitting with a piece of gas hose and clamps. Put some motor oil in the spryer, and pump it up. If all is OK, the oil will fill the oil galleries, and bleed off, relatively slowly through the bearings, and into the crankcase. If you have a missing gallery plug, or other major interanl leak, the oil will flow very quickly out of the sprayer, and into the crankcase, and you'll notice you're not building any pressure with the sprayer. If it seems all is well, you can re-connect the oil gauge, and start the engine, which should QUICKLY develop oil pressure. You'll have to drain out excessive oil before continuing to operate the engine, but some extra oil for the initial startup won't hurt, and, in fact, will be good. If there seems to be an internal leak, you'll have to drop the oil pan to track it down. With the pan off, you can again apply oil pressure to the oil gallery with your makeshift pressure system, and look for the internal leak. The better the fit of the rod and main bearings, the slower the drip of oil will be from each, and a missing plug, or other problem will show up as a BIG leak.
