Makin' hay
8ngreenhorn
06-20-2005 10:04:29
I'll also check archives, but can I find mowers, rakes and balers designed for an 8N, and if so, what are some of the names or models to look for?
old
06-20-2005 11:52:11
 Re: Makin' hay in reply to 8ngreenhorn, 06-20-2005 10:04:29
An 8N will run almost any 7 foot 3 point mower/sickle type that is. Ford 501 is one made for the Ford tractors. As far as rakes any pull type should work just fine. The big wheel rakes might not work well because of the lite front end on an 8N. Now as far as a baler the 8N is almost to small to pull one and if you do pull one it will be very hard on it if it will even have the power to make it do its thing, unless you fine one with its own engine then the 8N will pull it good, but with out the engine almost no way. Some poeple do it but it makes for a worn out 8N fast
6N's Short
06-20-2005 17:42:44
 Re: Makin' hay in reply to old, 06-20-2005 11:52:11
More than a little dangerous too, depending on terrain. I am going to stick to my belief here that you need more tractor to safely make hay. The weight issues alone are enough to scare the wisest away. Been cutting and selling hay for a while now and I know old has too.
old
06-20-2005 18:01:54
 Re: Makin' hay in reply to 6N's Short, 06-20-2005 17:42:44
Well yes I hay on this place since 1980 and when I was a kid helped a lot in the hay fields up in Neb. but that was a long time ago. Now I use 3 and at time 4 tractors to do the hay.
