A friend of mine and i are trying to get his 49 8N started. He ran it all last year,but this spring it would turn over but not start. It is a 6 volt system. This whats been done so far,1. He drained the tank and filled with new gas. The fuel is reaching the carb. 2. He was not getting fire from the coil so he replaced the coil, distributor cap,points, condenser, all the wiring, rotor, plugs, plug wires. The distributor was removed from the engine. We are getting fire at the plugs. 3. Had someone rebuilt the carburator. The engine will still not fire. We are thinking possibly the timing may be off, although according to the position of the rotor at top dead center, it is close. Should'nt it fire if the timing was fairly close? Any suggestions would be greatly appreciated. It's getting close to bush-hoggin time and he really misses using his tractor. I know the feeling.
