Order Ford 8N Parts Online
8n Ford Side view picture
Robert Alves
06-21-2005 19:28:59
Does anyone have a good picture taken in high resolution of a side view of an 8n ford tractor with a small three or four furrow plow behind it.I am looking at making a metal sign up . Any help would be appreciated.
Thanks
pat,maplehillfrm
06-22-2005 10:10:56
 Re: 8n Ford Side view picture in reply to Robert Alves, 06-21-2005 19:28:59
If you dont come up with anything I can hook mine up and take a picture. I have a 8n that was recently painted, (5 yrs). I have a 52 8n that has an original (rust patena to her I think it looks cool.let me know if you find anything, as it will be a day or two to get a picture to you.pat
Robert Alves
06-22-2005 10:16:56
 Re: 8n Ford Side view picture in reply to pat,maplehillfrm, 06-22-2005 10:10:56
Thanks Pat I haven't got anywhere yet. The link for the picture in a previous post is what I need but it has to be higher resolution to do the artwork from.
roger '40 9n
06-22-2005 05:32:21
hi Here is a photo from the photo archives.
It is not very high res but with some touch up
it will be good for a sign.
Link
Roger in Michigan
old
06-21-2005 20:57:31
Shot its all an 8N can do to pull a 2 bottom let alone 3 or 4.
FUNK can do
06-22-2005 04:16:28
 Re: 8n Ford Side view picture in reply to old, 06-21-2005 20:57:31
If a Funk is not a N then neither is the NAA.
That's what the Funk conversion was for, pulling
a bigger plow.
souNdguy
06-22-2005 10:32:04
 Re: 8n Ford Side view picture in reply to FUNK can do, 06-22-2005 04:16:28
A 3 bottom behind a funk is probably fine.. however.. a 4 bottom is probably exceding the limits of the drivetrain.. remember.. even if you strap a 100hp flame throwing hotrod engine to an 8n.. it's still stuck with a tranny and clutch, and diffy that is designed around 30hp and down...
Soundguy
Dan
06-21-2005 19:33:17
You won't find too many pictures like this as the 8N was a two bottom plow tractor...
Good luck,
Dan
Robert Alves
06-22-2005 04:01:59
 Re: 8n Ford Side view picture in reply to Dan, 06-21-2005 19:33:17
Sorry a two bottom would be fine. My father has an ertl toy with a 8n and a dearborn plow. Im looking to make a metal sign out like that. If anyone has a high res picture side view prefered it would be appreciated.
Thanks
