Order Ford 8N Parts Online
'47 8N I looked at today
RogerL
06-24-2005 20:34:25
third party image
I apologize if you see a similar message on the N-Club board, I'm trying to get as many opinions as I can, being a total amateur at this. This is the tractor I mentioned in my post yesterday.
For whatever reason, tractors are thin on the ground here in western Washington, and N machines all seem to be priced from around 2000 for projects to 5000 for nice ones. This one is just under 3000.
It looks to my uneducated eye to be pretty original and straight. It ran nicely, with some blow-by from the crankcase breather. Exhaust looked a bit rich on start-up but no oil smoke or coolant steam. No "goop" in the oil, either. Fuel bowl was brand new but the owner had buggered the threads on it, so it was leaking on the inlet side. Oil pressure was about 20lbs, hot.
Hydraulic lifted and held at the up position, but wouldn't hold in any itermediate position...not sure what that means.
This will be my first tractor, if I buy it, and my main reason for getting it is to mow my 10 acres of grass (there's a photo of my field on the web site below). The owner says when he purchased it there was a huge brush hog on it, but it was NOT happy pulling it. He said after about three passes through his field there was a lot of blow-by coming out the breather.
Tires were pretty much done. They're filled with a liquid other than water...didn't see any rust-out on the wheels, though.
It was a charming old machine, and while I would definitely restore it one day if I get it, it will have to earn its keep first. I'm not absolutely sold on getting an 8N (a 600 or 800 would be fine, too) there just isn't much for sale around here, and what there is tends to go fast.
My pasture IS all grass, no brush. Is there a sickle-type mower that can be fitted to one of these? What's the best way to go?
Thanks for any ideas, answers, or feedback, and thanks for your patience!
Brian in WA
06-25-2005 09:27:07
 Re: '47 8N I looked at today in reply to RogerL, 06-24-2005 20:34:25
Roger, Trusty Tractors in Shelton had an 8N with loader about two weeks ago. I think it was in the same price range as the one you looked at. I gave it a once over and it looked okay. May be worth checking out. Call or email them: (360)426-9299 or www.trustytractor.com.
BOB061
06-25-2005 07:29:07
Solid looking work machine and yet an easy restore. Price only matters to buyer and seller. If you get a machine to do what you want for a price you can swallow it's a good deal. I paid 1600 for mine here in michigan last year and it needed work, I don't mind wrenching, that's what I do. By the time I took care of the worn out engine and new rear tires I was knocking on the door of your price. Turn key and go plus supply and demand sounds fair to me.
BOB061
06-25-2005 08:41:02
 Re: '47 8N I looked at today in reply to BOB061, 06-25-2005 07:29:07
Oh, by the way. You don't need the front and rear wheel weights for mowing. You could sell them and get a couple hundred bucks back on your investment.
Larry 8N75381
06-25-2005 07:22:09
Roger,
If you buy the 8N, I would sure like to have some better (close up to show the details) pictures of the air cleaner. I have never seen one like that on an 8N. Don"t think that John Smith has a picture of one like that on his web pages. All the dust jars on the 8Ns are outside the hood. This one is under the hood. I have heard that the 2Ns had ones like that, but I have not seen one. I suppose that someone could have modified the 8N"s air cleaner and added the 2N dust jar. Sure would like to know what the deal is, and pictures would help.
Re: old"s comment about the year, I have 8N1045 which I figure was made the first week of the 8N production. The casting date on the engine is D97 which would mean that it was cast on April 9, 1947. All the authorities on the Ford N series tractors say that the production of the 8Ns began in July of 1947.
Regards,
Larry
BOB061
06-25-2005 07:40:31
 Re: '47 8N I looked at today in reply to Larry 8N75381, 06-25-2005 07:22:09
Thats an interesting casting date. The engine I just put in my 8N I took from a 2N. The casting number is D107 with a 9N serial number.
Larry 8N75381
06-25-2005 16:39:58
 Re: '47 8N I looked at today in reply to BOB061, 06-25-2005 07:40:31
Bob,
My S# is stamped quite clearly. The casting date is readable but not as good. That 2N engine must have been close to the end of the run. What was the full serial number on it - if you can read it all.
I would not be surprised to find that the engines had some over lap. Between the casting and the assembly into a tractor, there would be several stops where the block could get "out of order". Once cast the block would be moved to be machined and probably sat in some sort of "receiving" area. When the block was machined it probably sat until it could be assembled as an engine. Then it would sit again until it was finally assembled into the tractor.
I have seen S#"s and casting dates that indicate that the engine got into the tractor quickly. And then I have seen ones that seem to have taken several months. My 8N1045 block took three months - almost exactly. It would interesting to see the range of time that it took.
Regards,
Larry
BOB061
06-25-2005 17:07:34
 Re: '47 8N I looked at today in reply to Larry 8N75381, 06-25-2005 16:39:58
Just checked my serial # 9N238172 casting code D107 checked another 2N I'm working on 9N173602 casting code G114. That just suprised me that your 8N was cast before my 2N.
The Yank
06-25-2005 06:20:35
I have an 8N in Wisc. for sale. Back blade and front end loader & wheel weights. $2,800. Might cost a bit to get it to Washington!!!!
It is not in as good of shape as the one you're looking at. Buy it. It's only money. Think of all the fun!
You said "Hydraulic lifted and held at the up position, but wouldn't hold in any itermediate position...not sure what that means." The lift has two modes of operation. They are engaged based on a little lever under the seat on the right side. Read up on how they operate. They are "Position or Draft control" If the little lever is in Draft control mode, the lift will drop when you move the lever a couple of inches from the top. In Position mode the lift will go up and down dependant on where you move the lever.
Anyway, do some more reading and have fun.
Jim Cox
06-25-2005 05:25:29
with the rear blade it would bring $2000-2200 here in SW Missouri. If the demand is that high, I guess that price isn't out of line. My next will be a farmall Super M, they go around here for less than N's ( cause they're not as cute ) but I could settle for a tractor with a little more power.
Good luck. Important question since you have an english motor bug: Why do the English like warm beer? Lucas builds all the refridgerators! ( I've had five Volvos, I understand the bug all the same )
Jim Cox
SW Missouri
Tymoc
06-25-2005 02:05:22
What a beautiful pasture. Liked it so much I'm going to use it as my background. If I owned it a mower would never touch it. Maybe a few sheep. Don't care to much for golf course land.
guest
06-25-2005 03:45:11
 Re: '47 8N I looked at today in reply to Tymoc, 06-25-2005 02:05:22
You can easilly carry an N on a
car hauler. I would expand my search area and borrow a buddies trailer. After all it is a one time trip
to the farm. I think the owner may have
been sending you a message about the N not being able to power a brush hog.
You might be in for an immediate rebuild.
George
RogerL
06-25-2005 03:19:51
I'm kinda with you, Tymoc. But unfortunately, it would only last that way for about a year, I think. It's only been a year since the cows left and already blackberries and scotch broom are making their moves. Mowing at least knocks that stuff down, and I'd only being doing it a few times a year.
The Mrs. would like to have a place to give the collies their head and right now they disappear into the grass immediately when they get there. This is apparently NOT part of the training program.
I'm also concerned because the neighboring pasture has that grass which can be dangerous for dogs growing in it, and we don't want that to end up in our place.
We're thinking of a few sheep to keep said collies busy, once we build our small little house there, which might make mowing moot on some of it. We live on one of the Puget Sound islands in the rain shadow, or a fringe of it, and so I might try my hand at haying, eventually.
How's that for off-topic? Sorry.
Dell (WA)
06-24-2005 22:42:15
Roger..... ...looks like a typical used 8N. It has the 20A 6v genny, that is good. The ag-bar tires look to be about 50% worn. Not good, not bad, adequate for pasture mowing. Probably last for 10 more yrs. Gitta "brushhogg" for pasture mowing, 5ft is correct size. Iff'n it don't come witha 'hog, byte the bullet and buy one for about $500 new. (iff'n you think buying a used tractor is difficult, wait until you try and buy a used brushhog; tractors eazier) Don't even muckka'round with sickle-bar, good for makin' hay. Western Washington makes LOUSY HAY. (don't ask) External wheel weights are "nice" but not needed for brushhogin'. Fluid filled tires for traction still NOT NEEDED for brushhoggin'.
Know what you mean about 8N availablility in Western Washington. I hauled mine up from near Salem Ore 15 yr ago, but it was a Walla-Walla divorce settlement for $2000 cash. But I gott 10 hrs of quality daddy time bouncing down I-5 with my 10yo son and his scouting budddy. He's now 2Lt USAF.
I was more interested in the white MGB, yours?..... ..Dell, head shepherd, RockyRidge SheepStation; 15 awesome acres at the foot of 14K Mt Rainier where I raise and train Australian Shepherd herding dogs
RogerL
06-24-2005 23:22:58
 Re: '47 8N I looked at today in reply to Dell (WA), 06-24-2005 22:42:15
Dell, MGB is mine. I'm a British machinery addict, have other old cars and bikes. Was originally shopping for a David Brown or British Ferguson... maybe at some later time, wife would like the pasture mowed sometime soon. Like Fords, too, have a great old '68 F250. Also have two border collies.
RogerL
06-24-2005 21:54:05
The serial number was in the 54,xxx range. It did have 8N on the engine casting. My knowledge is very, very small, so I apologize if I've misstated anything. I just repeat what I'm told (being married has taught me that!).
souNdguy
06-24-2005 21:58:34
 Re: '47 8N I looked at today in reply to RogerL, 06-24-2005 21:54:05
54xxx range makes it an early 48 model.. ( 37xxx was first 48 model.. 141xxx was last 48 model.. )
Soundguy
old
06-24-2005 21:09:07
Can not be a 1947 8N they didn't start makeing them till 1948. Does it have a 3 speed or 4 speed tranny. If its 3 speed its a 2 N or 9 N if its a 4 speed its an 8N but that would make it a 48 or newer.
Russ SoCal
06-24-2005 22:03:19
 Re: '47 8N I looked at today in reply to old, 06-24-2005 21:09:07
old,
Definitely an 8N. Hood emblem and grille, script hood, battery location, front wheels, clutch pedal, running boards and rear wheels all are 8N distinctively. Folks like to call em 47 8N's when they came off the assembly line before December 31st. Bet if they bought a brand new pickup last Fall they don't call it a 2004.
Russ
souNdguy
06-24-2005 21:35:42
Could be a 47 8n, even though they were for model/year 1948 My manual states that the beginning SN for 1948 was in the 30,000's.
To the original poster:
In any case.. it looks like a decent old machine. I love the wheel weights.
Is the draft/position lever under the right side of the seat flipped 'up' if not.. that may cause hyd issues due to the draft control. Either way.. if it is out of adjustment.. or has a worm cam follower.. it is easy to work on the hyds.. etc.
Soundguy
