push blade on front end loader
9N'er
06-25-2005 16:55:07
I think I found a Ford push blade for my Ford 703 FEL. It does not angle but rather is straight...it"s better than what I have...but will a straight blade be ok for snow plowing? or should I keep looking for an adjustable angle blade?
thoughts?
9N"er
Steve in MI
06-26-2005 08:27:33
 Re: push blade on front end loader in reply to 9N'er, 06-25-2005 16:55:07
I have a Ford Angle Dozer Blade (19-2) on my 8N for sale.It comes with a mounting frame(19-80) that you couldn't use withyour loader, but you might be able to rig it up to your loader frame.
old
06-25-2005 18:35:03
If you don't have to push very far it will work, also if you don't have to push a lot of snow. But if you have a place like I have it will not work, mile long drive way. I built a V plow that I use on my 801 tractor with loader.
Neal
06-25-2005 18:33:47
A straight blade will not be much better than your front end loader. Once you get a full load of snow in front of your blade, your wheels are just going to spin even if you have chains. Guaranteed! You need a blade that will angle to allow the snow to be pushed off to one side if you have a significant snowfall.
